Whitebread
- Jan 28, 2002
I just finished running some ethernet cables through my house. I dedicated one of those lines to my fathers Laserjet 4 printer. It has a number of RJ-45 jacks in the back, which I assume enable the printer to be connected to a LAN where it can be printed too. Now, I terminated the cables and tested them, they work fine. My first problem is that the connection light on my netgear switch is not lit. Anyone know why? After I will probably need help adding the printer to each computers list of printable printers. And, if you guys need pics of the jacks on the printer, I can provide them.
As soon as I connected a cable to the second jack on the printer, it printed a page with about 5 very small symbols, if that's of any consequence.
Extended Systems ESI-3280 is the name of the "switch" in the LaserJet. It has 8 ports.
All of this hardware is old. That extended systems device couldn't be found on their website and HP has limited information about setting up this printer for printing across a network.
HELP!!
HELP!!
