Flogger23m
- Jun 19, 2009
Hello all.
I am having a slight issue, I am trying to make a server for the game Red Orchestra Ost Front (server set up looks identical to UT2004).
I have a WRT300N Linksys router.
For whatever reason, I am not able to host a game. I am trying both a listen and dedicated server. I really only need the listen server to work.
I have looked online, and it says I need to use these ports:
7757 UDP/IP (Game Port)
7758 UDP/IP (Query Port)
7767 UDP/IP (GameSpy Query Port)
28902 TCP/IP and UDP (Allows your Server to Connect to the Master Server Browser)
8075 TCP/IP (Port set via ListenPort that your WebAdmin will run on)
20610 UDP/IP (Steam Port)
Now, I really don't know anything about ports, or how to forward them. I know how to access my router, but I am not sure where I would exactly forward the ports (I am assuming under the Gaming & Applications tab).
I have also made sure Vista made an exception in its firewall for the game and Steam.
Any advice?
Any advice?
