seperate discs. (I meant RAID 1)
My system was setup with two identical hard drives. What I did was parition them so both had C: and D:. Set to Mirror. I've been wondering sometime now if using Mirroring has created latency. Based on the system I feel it should perform better and decided this was overkill. So, I did a Ghost of both partitions. Then deleted the RAID Array. However, I'm having trouble getting the system back up an running.
My intent now is to use one physical disc as C: and the other as D:. I thought I could simply restore the Ghost image of partition C: to the 'C drive HDD' and restore the Ghost partition image to drive D: So instead of partitioning the discs and mirroring them I run them seperately with a drive letter assigned to each.
However, I'm having trouble. When first restoring from the Ghost boot disc and then rebooting I rec'd a message stating that Windows couldn't load due to a missing HAL.DLL file. I'm concerned that there may be more of this.
Anyway....should I have deleted the disc array first and then did a Ghost of each partition, format the discs and then do the Ghost restore or ?
Stuck and my system is down. This is my business desktop and I thought I'd have it back up and running by now.
Thanks...
Thanks...
