Need help removing heatsinks.
GetFunk01
I need help removing the Tweekmonster RAM sinks off my vidcard. I put then on with Artic silver epoxy. How do i get them off.
if you used a pure epoxy mix you wont be taking those sinks off your video card without the chips still attached.
