Okay guys I really need some help.
I set up a server back at home (away at school now) to download store videos, pictures, mp3s etc...
I just have 1 problem! I can't remote log in!
Every tim eI go home and set it up it works for a bit, but then it just stops working all of a sudden. Here is the situation:
I am running Windows XP Pro on the server. I changed the port on RDP to a different one (since I have several computers on the network) that's not a default. I have several computers and changed each to a seperate port. I have a Netfear router that I have set up port forwarding to each computer with that specific port...
I have Norton internet security installed as the firewall, but from what I could tell I don't think that is what is causing the problem. Or maybe it is?
I have no problems logging into the server with RDP from within the network but once I am outside I can't connect to it. The only thing that seems to work is if I change the port. Then again it would work for a little bit and then stop working.
Can someone PLEASE help me get this thing working. It is really frustrating because once I'm away at school I can't access the computer at all.
