Hey guys, I just took apart my PNY 6800gt to reapply the thermal paste. I have never overclocked it and I was getting about 78-80 degrees C. So I wanted to reapply just as an extra measure of caution. All I have currently on hand is AC3 and AC5, which I think I recall reading might be a little too thin for mem chips. The thermal tape that is on there now is obviously crap as you can see by the pictures. Do you guys think I would be safe using either of the Arctic Silvers for the mem and/or the gpu? Im just worried there will be too much of a gap, hence the being to thin part. Also, check out the bracket that was on the back, are they known to melt like that, lol. I thought I had decent ventilation in my case, guess not. Please give me your recommendations and suggestions about anything else I might have missed, this is my first time doing this. Ive already used rubbing alcohol and removed all the old stuff from the gpu and heatsink. Just need a direction to go from there, whether or not the paste I have on hand is safe. Thanks guys and gals.
