need help quick
KingTKS
ok i got new computer parts and something isn't wrong and i need this computer working by tommorrow morning.
here is the deal i bought a new case mobo and power supply
the mobo is a m7ncg 400.
i hoooked everyhting up correctly and when i went to turn on the computer it powers up but nothing happens on the monitor. i also noticed that only th8ings that power up are teh fans through the power supply and the mobo. my hard drive wont' turn on and neither will my cdrom. i tried switching around the connecters but didn't help. i thought it was the power supply but i got hte same results. then i was sure it was the mobo and i rma it but they said it tested ok.
so what is the deal?
please help quick
power supply is an enermax eg285sx-vb(w)
odd, unless there is some other way to fix it that i am not aware of i'd take the PSU back
i'm almost positive its not the power supply.
even if i don't need the hard drive and other stuff
if my mobo is powering up i should at least be able to see startup on the screen
just assume the power supply is fine because i tried it with a different power supply and i had the same results
Check your jumper settings against your manual. Make sure all your connections are all plugged in correctly. try reseating your vid card. or try using a different vid card. What vid card are you using? Some really old agp cards do not work in newer mobo's because of voltage differences. also make sure that if your vid card has a power plug on it that you plug it in. Hope it helps.
Start to finish, here's the best thing to do
1. Unplug EVERYTHING, remove all the cards, the RAM, the motherboard, etc. Leave the CPU installed with the heatsink (it helps me with removing the motherboard since the heatsink is easier to hold on to)
2. With the motherboard out, check your stand-offs in the case. Make sure you have one for the right holes on the motherboard and no extras. You don't need one for every single mounting hole. With the keyboard/mouse and other ports facing left, you should have 3 in a row directly at the back of the case, 3 in the middle and if your motherboard is larger, 3 at the front. Some motherboards have a slightly different mounting hole arrangment so double check.
3. Check to make sure the heatsink is properly mounted on the CPU. AMD heatsinks have a lip that will fit over the edge of the socket. In your board's case the lip should be facing up (from the viewpoint I mentioned earlier, it would be away from you). Remount it if necessary taking care NOT to crush the CPU Core. Reinstall the motherboard.
4. Connect the power switch from the case up and the PC speaker up ONLY. Yes, leave the reset, power LED and hard drive LEDs unplugged
5. Plug in the power supply to the motherboard, don't forget about the 12V 4 pin plug as well. Turn the power supply on and hit the power switch. You should get a long beep that repeats over and over. If you don't, either your power supply, motherboard or processor are bad. You would need a spare of each to continue testing.
6. If you did get the long beep, install the RAM (obviously with teh system off) and power it back on. Now you should get one long and several short beeps. If there are no beeps, the RAM is bad. (if you have multiple sticks, install only one at a time and repeat until you either get the beeps mentioned, or you've tried them all and it doesn't work).
7. If you did get beeps, power off the system and install your video card. Now connect the monitor and keyboard up. Turn the system on. You should get one beep and get a display. If you get the same beeps as before and no video, you have a bad video card.
8. If you've made it to this point, your base hardware is good. Your next step is to install the remaining hardware one piece at a time, power up the system and see if it tries to boot. If after installing someting, the system stops giving you a display or freezes, the last part you put back in is bad.
These are the basic steps to solve nearly any non-booting, non display issue with a PC. If you were to take your PC to a shop this is the same process they would do to resovle the problem. Let me know how it progresses.
UPDATE:
Guess I should have researched the board a bit before posting. :D
You should have 8 stand-offs total, 3 on the back, 3 in the middle and 2 at the edge of the board.
