Need help quick with bios
Hey I was needing help for a friends sis motherboard. When i try to boot from the cd it never gets to the blue screen that is the intro. It goes through a process that says Searching for bootrecord from cdrom...not found. Also for the boot sequence it says CD-ROM > IDE-0 > and Floppy. If it was actually recognizing it it should say ATAPI CD-R/RW correct? Please help me out as soon as you can. Thanks, Tyler
Is there an option for boot menu when it is POSTing? If so, press that button, and choose DVD/CD.
Oh, and in the BIOS, see if there is an option for removable drive, or if there are multiple dvd/cd drives, put them before the IDE-0 to be extra sure that it boots from it. Also, make sure the CD/DVD you are using is bootable and if it is a disc you burned, then try burning it again at a lower speed to be sure it is a good disc.
Theres no option for removeable drive. IT says IDE-0 < Floppy < CD ROM. No removeable disk. And for c it says something like zip drive C? He has 1 hard drive 60 GB. Reset the cmos battery and its doing the same thing. Any other advice?
