Need help quick- which screws to use?
mac451
Im installing my motherboard, and already have the brass standoffs in. However it doesnt say what screws to use to connect the mobo to the standoffs. One type of screw is small and the other is larger with a washer looking thing attatched to it. Anyone know which one I use?
Im still not sure. I installed the larger ones but they dont tighten all the way down to the board. Is that how it is supposed to be? I will try to get some pics up
Doesn't matter which ones you use - only thing is you have to make sure that the motherboard is tightly installed on the raisers. The screws should go into raisers properly (not forcefully or too loosely).
mac451 said:
Im still not sure. I installed the larger ones but they dont tighten all the way down to the board...
The motherboard has to be tight against the standoffs.
