Need Help Quick Please!!
DeadPixel
Alright just randomly my new monitor (2407FPW) is experiencing MAJOR glitches. There are blue lines and blue dots that randomly form everywhere and dissapear. Some yellow spots also form.
I have 2 monitors hooked up to an old card (9700, new monitor hooked to dvi old to vga) and I can't tell if its the monitor or the graphics card.
Either way, it's no biggie but I need to know asap so I can send the monitor in with the warranty.
#1) Use common sense
#2) Test one monitor at a time, if both exhibit it, its likely the video card
#3) Check your video card temps
#4) Check cabling
#5) This was not urgent (and caps dont help your cause)
if the card was the problem I think both monitors would experience similar problems... turn off your dual screen, and run each monitor through the DVI port, via dvi-vga if you must... See if maybe its the dvi port... See if its the Dual screening... If You only experience in one monitor, then you have your answer... if you turn off Dual and test and dont have it at all... Well theres another answer... You can figure it out, I have faith in you :)...
(Edit:... one minute late... lol...)
