I'm using a dangerden system, which has worked well for about 6 months, with ahydor pump and thermochill rad . After about 4 months, I noticed a bit of radiator die (which I put into the res) on the floor of my case. Well, the leak continued to accelerate, and has gotten the point where I took the whole system out and leak tested. I'm getting a leak at the outlet of the pump. This didn't surprise me, as there was a leak there when I first put the system together, at which point dangerden advised me to put some vaseline around the seal, which seemed to worked, but it seems to have been a temporary fix.
So my question: is there a better fix which is closer to permanent, or do I need to keep up with routine maintenance? Is it my pump, and if so, can you recommend a good one? Also, the lines have become gunked up with algae or mold, or something. Would a flush with some bleach and water fix it up?
Thanks in advance.
Thanks in advance.
