Need help, power is on, puter won't start
CrackatiCz
So today, I just bought a new computer, used from a guy on Craigslist, about $575, here are the specs I will make it very short and prompt.
E6300
680i EVGA Board
2 gigs xms2
160gig hdd wd 7200 RPM
7900GT KO 256mb
Ultra X 450 Watt, Thermaltake 500 watt PSU, I used both
Anyways, I see the leds on the motherboard, blue and yellow on the very top right, so the motherboard is receiving power. I get a screw driver or a piece of metal and touch the pins where the power switch should connect to, no spark, nothing, no turn on. Can anyone help me? I tried two PSU's so it can't be the PSU, CPU heatsink is plugged in, P4 connector is plugged in, I ran in with just the motherboard and cpu, on a big piece of foam. Your help, and advice will be commended. :confused:
Thanks!
-CrackatiCz A.K.A. Juje:D
Was it working before you bought it? lol.
/*------------- <cut n paste> -------------*/
If you have both the 20/24 pin main ATX connector plugged in, AND the 4-Pin ATX12V P4 CPU connector plugged in, then the board should boot fine.
You could test the PSU. Jump start it (on the main atx connector, short the green wire with any black wire, using a paperclip), and see if it stays on. If not, then its most likely a faulty PSU. If it works then proceed (though it still may be a bad PSU).
Setup everything outside of the case, with the mobo on top of its cardboard box. Plug in only the essentials:
- PSU (namely: main 20/24-pin ATX connector and 4-pin ATX12V P4 CPU Connector)
- CPU w/ HSF
- Single stick of ram
- Videocard if there is no onboard video
- Monitor
- Keyboard
- System speaker/buzzer
* Use a screwdriver if your board doesnt have an onboard power switch. Jump the two power switch leads to turn the power on.
If it won't post, try different RAM slots. If it still won't post, pull out the ram (so no ram in the system) and listen for error beeps. If none, pull the vidcard and listen for error beeps. If none, re-seat the CPU/HSF and try again. Report back with results if you're still having issues.
/*------------- </cut n paste> -------------*/
Aright, well I found out it was because the Power Sw. pins were in a different location then all motherboards, turns out I was jump starting the wrong pins, everything works, hooray!
