need help please
Creamyapples
Arock k7vt4a+
Amd XP 1800+
1 GB pc 2100
Nvidia 5700le 256mb
Turtle Beach santa cruz
Ami-ia 56k modem
120 WD HDD
Windows XP Home
When I load dark age of camelot its freezes up for a couple of seconds, Then dumps my connection, Then sometimes while running an IE it will freeze up, But not dump connection. Any suggestions?
I would look at your RAM and video card drivers first. Download the newest driver for your card and, if that doesn't help, download memtest86 and run it for several full passes.
Any errors means you have bad RAM.
Cean up windows "carefully" with msconfig/defrag and reinstall DoAC. I'd try that first before considering your hardware, esp. if it has been working ok so far.
