Need help picking out a 775 mobo...
vexeus
I'm overwhelmed with the different chipsets available for core 2 duo setups. Back when I got my Opteron 165, there were only 2 options. With core 2 there's 965, 975, 680i, RD600, and I'm probably missing another few. I need a recommendation for a mobo that is the best overclocker.
So instead of leaving this long winded post that I had planned on, I'll just ask straight up:
What's the best 775 mobo for overclocking an E6300? Let's assume everything else in the system can handle whatever you throw at it. It must also have a black PCB and run FSB 500+.
(Yes I've searched. I can't seem to find a good answer.)
My recommendation is the eVGA NF 680i. FSB is known to oc >500MHz and the pcb is black!
The 680i or get an Asus P5B Deluxe. Depending on memory it can do 500mhz+.
On a side note if I were you I would consider the E6400. You get a higher multi on basically the same chip.
I've got some Mushkin Redlines that are supposed to do 4-5-4-11 @ 1000 Mhz. I originally was going to go with the E6400, but my ram is pretty good, so it shouldn't be holding me back on the multiplier.
Am I correct in thinking that the ram will not be a problem when trying to do 500x7 with an E6300?
(I know this is a "wishful thinking" overclock, but I just want to make sure the ram isn't holding me back)
