NOFEAR10199
- Jul 5, 2016
Ok, Please help me with my CPU issue and Thank You in advance.
I have my Current CPU with a 3930k OC 4.6 which I use to do Acad and Chief Architect (Rendering) and I also play games on it. I recently built a Second New CPU with a 6700k OC 4.5 which is used by Staff & Family to do occasional work and gaming. I loaded both with the same file and rendered it, I had all the settings the same and the 6700k was almost twice as fast? I did some other side by side tasks and the 6700k would either match or blow the 3930k out of the water. So now I want to build a new computer that I would like to spank the 6700k. I would spend $2k-$3k on this CPU but I don't want to do that if i would only see a small improvement over the 6700k. Or is there something that can be done to the 3930k it has 2 additional cores and higher GHz? Please help me pick the correct processor as Intel is taking to long to design one that is hands down better than the rest.
Current CPU: 3930k O.C. 4.6 on water h80, (4) 16gb ddr3 1600 ram, Asus P9X79 Deluxe, 480 SSD & Evga 1080 FTW. 850psu
New CPU: 6700k O.C. 4.5 on water H100i, (2) 16gb DDR4 3400 ram, ASRock Z170 gaming-itx/ac, M.2 Samsung 950 512gb, Evga 1070 FE
