I'm thinking about getting a water cooled system. I was going to get a Lian li 1200B case, then later it came to my attention that Koolance makes a very nice looking case PC4-1025BK ( a Lian Li case with an intigrated water cool system).
The things I would like to accomplish with a water cooled system are.
1. I would like to OC and still have a quiet rig. I know radiators and pumps make noise, so I would like to keep it to a minimum.
2. I would like to get a case I'll have for a while, that is why I'm willing to spend a little extra.
3. I am concerned if I get the Koolance, how reliable are they? Are there better units I should look at?
Primarily I am going to use it on a
E6300, later a E6600
1 SATA HD
CD/DVD RW
9750GX2
Not sure if I need to cool the Northbrigde and video card or just the CPU.
I would like a cooling device that is built on the the case, not one that is loose like the new Corsair unit and I think the radiator really needs to be outside the case, else it would heat up the case too much, I think.
1 SATA HD
CD/DVD RW
9750GX2
