Need help picking a router
kumquat
I currently have a Linksys E2000. I'll be giving it to a friend who is moving to a new apartment. I want to replace it with something else.
I like the idea of DD-WRT and would like something that is well-supported. The Buffalo routers like the WHR-HP-G300n looks like a nice unit but there are a lot of very negative reviews on the unit. Also doesn't have gigabit, which is kind of a necessity.
The Asus routers look good. Thinking about maybe the N16 but I don't need the USB and print server nonsense.
I'm also looking at the Netgear WNR3500L.
I have a 15/1 cable connection with up to 3-4 wireless clients and another 4-5 wired (I have a separate gigabit switch so number of ports isn't an issue).
I'd like to spend no more than $80.
Any suggestions?
Search the forum dude.
Hint, check the sticky at the top of this section.
There is a sticky at the top of this forum covering this topic.
My personal opinion
Build one yourself with Untangle. Simple easy to use yet powerful.
If you get bored with that try using PFSense.
My personal opinion
and if he gets bored with that, he can re-read the thread ! LOL
Netgear WNR3500L With Tomato USB or dd-wrt
TP-Link WR1043ND with OpenWRT, or Gargoyle 1.5.4 or never.
