onetwenty8k
- Nov 24, 2006
Hello,
I'm having trouble migrating an opensource room booking script called iCalScheduler (http://sourceforge.net/projects/icalscheduler/). When adding a new user in the admin panel, the password in the form gets passed into the MySQL table as (null) (but in an md5 hash).
The form code is all fine, you'll just have to trust me on that. The command that loses the md5 is
So inside ical_parser, the only commands that are relevant to $password, is
Date functions has nothing relevent either, so in init.inc, here is the code. Can you tell me if anything looks off to you? I've been looking at it with tunnel vision, I need some help.
http://pastebin.com/89PW4X30
You need PHP version: 5.2.17
He has deprecated commands. When I get this problem fixed, I'm going update the script up to standard PHP and put it up on sourceforge.
HTML:
include_once(BASE.'functions/ical_parser.php');
HTML:
require_once(BASE.'functions/init.inc.php');
require_once(BASE.'functions/date_functions.php');
