Hi, im having some problems with my system, only when I try to play just about any game thats considered even close to high end graphics. What will happen is my computer will freeze and i'll get a repeating loop of the last 2 seconds of sound that I heard. I have to then manually turn my computer off/on. Can anyone help me? I suspect its a cooling issue because if i let the 30degree weather from outside come from my windows and freeze up my room and i put a floor fan near my case, it runs fine. Anyway, here is the setup. Advice on suggested fans would be much appreciated.
Nvidia 6600GT 128mb AGP
Intel Pent 4 3.0GHZ
800MHZ FSB
1GB RAM
1 120mm fan blowing outward of the back. 1 CPU Fan 1 80mm case fan blowing out on side of case. Any help would be appreciated
ALSO, my ASUS Probe reads the following at IDLE:
CPU TEMP 46C/114F
MB TEMP 31C/87F
Intel Pent 4 3.0GHZ
800MHZ FSB
1GB RAM
CPU TEMP 46C/114F
MB TEMP 31C/87F
