Need help Overclocking P4 640...
PScherer79
Need help with setting FSB and Voltage for a P4 640 (3.2Ghz) to get maximum overclock...
FSB Currently set = 225 (225x16 = 3500Mhz)
CPU Voltage = 1.3V
Should I raise the CPU Voltage?
My system:
Shuttle SB83G5
Intel P4 640 3.2GHz w/ HT (64-Bit)
1GB Kingston HyperX PC4000 (Dual Chan)
BFG GeForce 6600GT OC 128MB (PCI-E)
ASUS CX2338x TV/FM Tuner
SeaGate Barracuda 80GB SATA
NEC ND-3500AG DVD±RW DL
XP MCE 2005
Damn! I usually work with Athlons so I could be wrong here, but isn't 1.3v low? The last P4 I had was a 2.8C and I had that running 24/7 at 1.6v. So, I say hell yes - crank that voltage up! (assuming you have at least a decent heatsink)
