I'm having trouble getting a decent overclock on my e6600 using the gigabyte p35-ds3l motherboard.
I have followed this guide (http://www.hardforum.com/showthread.php?t=1169366). I know this is for the p965 but the bios configuration is very similar to mine.
I also tried following this guide (http://www.legionhardware.com/document.php?id=677&p=2).
My problem is that I can not even reach a stable 3.0 GHz.
I set the FSB
RAM ratio to 1:1 using the System Memory Multiplier (SPD) to 2.00 while using a CPU Host Frequency of 333 MHz (FSB), which effectively makes my memory frequency 667 MHz (I use PC2-6400 RAM).
I tried setting the CPU Voltage Control as high as 1.475V as well as setting FSB OverVoltage Control to +0.1V.
When I try to run prime95 it crashes after 10 minutes.
Am I missing something here? Why can't I get a decent overclock?
I set the FSB
