Need help overclocking a MSI Neo4-F
Bill Clo
Hello. I'm having trouble overclocking a MSI Neo4-F board... I can get the system running Folding at Home stable at 2.2ghz (220x10), but as soon as I go beyond that, it crashes repeatedly. Sometimes it hangs on the "verifying DMI pool" section of the POST, sometimes it won't get that far.
2.2ghz, stable, 2.25ghz very unstable, can't get beyond POST, tried 2.3ghz, no post.
System specs:
A64 X2 3800
Thermalright XP-90, with a 56cfm 92mm fan.
Corsair Value Ram, 2 x 512mb, memory speed is locked at 200mhz, settings CAS3 8 8 3, 1T.
Antec Truepower 2 480w power supply (reads 11.91v under load)
Cheapo PCI video card (this system is for Folding at Home only)
1 Western Digital 40gb IDE hard drive
Temperature is 43C at 2.2ghz, Folding.
At 2.2ghz, it's stable for over a day Folding.
Settings: HTT 4, also tried 3
Cool&Quiet disabled
Can't find any thermal shutdown temps/etc
CPU at 1.375 (1.35v default)
NF4 chipset voltage upped to 1.55v from 1.5 default
didn't mess with memory since it's locked at 200 mhz.
I'm not using any SATA drives, and SATA is disabled.
I've also tried a lower multiplier and higher FSB, and the system won't POST.
Any ideas?
What he said but turn off aggressive timing and replace the thermal wax on the NB with AS5
fried my NB on my Neo-4 F with that crap and a 3000 venice at 2.8
125$ lit on fire and thrown outta the car's window :mad: :mad: :mad:
aggressive timing [or aggressive clocking {can't remember}] it's a little above dynamic overclocking And Turn the cpu to 5% overvolt [good to 2.7 W/3000+]
I found out that for some reason my chipset seems to top out at around 230fsb. 226, it runs fine, 230, it crashes every time. I think I'm going to look into maybe a better Northbridge cooler and see if that helps any; this board ought to go a fair bit higher, fsb-wise.
I set my RAM divider to 5/6 or 166, pushed that same RAM to 250 @2.85 volts and CPU voltage to 1.47 and the 3800 X-2 does 2.5. XP-90 cooler with ThermalTake Cat-90 fan.
Folding two clients 24/7 max temp is low 40’s. Don’t try a 1 to 1 over clock with most RAM and with the divider you will never know the difference.
Luck
You may had a bad board. Mine posts up to 305FSB and does 320FSB in Windows with Clockgen . . . and yeah, always run a divider if your running into stability problems, though the fact that you can't even post at 230FSB is a little suspicious. What BIOS are you running? 1.71 Beta BIOS is the best one . . . also make sure "CPU Spread Spectrum" is off!
I suggest you flash the BIOS to 1.71 Beta, set DRAM @ 166, set your NF4 voltage to 1.7v and see if you can post above 230FSB . . .
I'm using the BIOS which came with the board: v1.9. I did try DRAM @166 (which was the only way to get anywhere), CPU volts at 1.4, even tried the +3.3% over VID option. Spread spectrum was already off. I've tried chipset volts at 1.55.
I'm starting to wonder what else is up. Bad memory? I had the same inability to raise FSB very high with the previous board (Abit KN8)...except that with that board, same options except DRAM speed at 166mhz, couldn't get it past 207 fsb.
I initially thought the problem was bad power supply, replaced that with a better one, problem persisted. Got the current mobo instead, tinkered a bit with it, and can only get to 226fsb or so. I'm not real impressed with 13% overclock, considering what I've seen others getting...ugh.
I'll try raising chipset volts some more, and see if I can lay my hands on a copy of the earlier BIOS.
I ran Memtest on the memory for awhile, no errors. It appears to be the CPU itself. I got the board up to 230 FSB. Raised CPU volts to 1.46 (6%) over VID, increased chipset voltage to 1.6. Now I have to get a better CPU cooler fan, as the one I have isn't keeping up (temps are 50-51C). If I get a better fan, I may be able to squeak out 2.4ghz (240 FSB). This X2 3800 wants higher volts to get any significant OC out of it. Suprising, when I've seen some people claim 2.6ghz on default voltage. I don't know if they're full of it or not.
