Need help Optimizing my BIOS settings - MSI K9A2 Platinum
swoody
Ok, well I feel that my BIOS is lacking as I haven't much of an idea on how to set it up properly, and I was hoping someone more experienced with tweaking BIOS and this motherboard in general can help me out here. My Vista Home Premium install seems to take FOREVER to load, and is really laggy once it does boot. I'm hoping with some BIOS tweaks I can decrease my boot time, as well as take some of the lag out of Windows.
I already have the BIOS setup to only boot from the HD, so there is no delay in it trying other devices first, however, my boot times are still astronomical. When my computer first boots there is a long delay between the time the BIOS post ends, and the Windows loading screen appears. Then when the loading screen does come up, it takes 12-15 full sweeps across the little loading bar until the loading screen goes away. Then it'll have another lag before it automatically logs me in to the system. Once the computer is booted up, I still get a lot of lag in the system. Opening menus has a noticable delay, and when I right-click on the desktop there is usually about a 10 second lag while the 'busy' mouse icon appears, before the menu will pop up. Also, popup notifications make the system lag noticeably. I don't have any programs that start up with the system - that includes no Anti-virus software or 3rd party firewalls.
My system:
-MSI K9A2 Platinum V. 1 - Upgraded to newest BIOS for Phenom II support - American Megatrends v1.8 - 04/21/2009
- Phenom II X4 940 Black Edition. Only overclocked to 3.2Ghz, voltage set to 'Auto' in BIOS, Runs very stable 24/7 @ 100% usage
- 2x1GB OCZ Platinum DDR2 800mhz RAM - I hear this is rated to run between 1.8-2.2v, but when I set it to 2.0v in BIOS, it still doesn't come up as 2.0v in Everest or CPU-z
-Dual 9800GX2's - not running in SLI. Latest GeForce Drivers. Dummy plugs on DVI outputs to make them active for F@H.
- WD 500GB Cavar Blue - Windows is only thing on disc, but partition only takes up 100GB, rest is unpartitioned
-Nothing else is hooked up to the rig besides a PS/2 keyboard, a USB mouse, LAN ethernet cable, and my monitor
I'm open to any and all suggestions you guys may have! Anything I can disable in the BIOS, or any settings I should keep on... Any advice or tips are greatly appreciated! Thanks in advance!
woody
Did you install vista with both of those GPUs installed?
If you did take them out and do a reinstall with a single gpu installed... i know this sounds weird but that same thing happened to me.
If that doesnt do it then you need to check your HDD.
Also make sure you have the latest BIOS.
Well thanks for the quick response nitrobass24 :D
No, I actually had a single card installed when I installed Windows. I don't remember the last time I did a fresh install of the entire OS, but it was either with a GTX260 or an 8600GT hooked up.
I was going to check out my HDD as well. I'm going to give that a shot tomorrow with the manufacturer's HDD diagnostic tool, and boot it straight from a CD.
And I do have the latest BIOS update. As I mentioned above (in my long post ;)) I reflashed the BIOS to the newest version to guarantee support with my Phenom II X4.
Oh, and just to let everyone know, my BIOS is American Megatrends v1.8 - 04/21/2009
Nobody else has any ideas about this?? What about just tweaking my BIOS in general? Can anyone help me out there?
Try a HDTune test on the HDD and post a screen shot. That could explain your large windows loadtimes.
For bios, are you using AHCI? I ask this because most times you will need to load AHCI between BIOS post and loading windows. That can add a good 10-15 seconds to loading.
Any minor bios tweaks like disabling unused ports (parallel, floppy disk, etc.) or caching BIOS may improve speeds but I have never noticed and some of those tweaks may lead to problems.
Yea but the problem is that its not the BIOS Post times.....its OS load times, and even lags once its fully booted to the desktop.
When did this start to happen?
What did you change?
Well I have noticed a bit of a decrease in boot time since I've been playing around with the BIOS options. I've mostly just disabled un-needed things, and boot straight to the HDD. For as far back as I can remember it's been like this. It went down by a bit when I raised my FSB, but I'm guessing that was just from speeding up the system.
Yeah, I've tried to disable different hardware and ports in the BIOS, but I'm sure there's more I can disable. As far as AHCI, I believe I have it set to 'IDE' in my BIOS. I'll give that HD tune a try, and see how it goes. Are you just interested in seeing the 'Benchmark' option?
I would like to see a HDTune, and an IOmeter benchmark.
Also tonight run your drive through a diag. either the manufacturers or drive fit test.
Well, I checked out their webpage. Do I need to use the IA64 version? The only one they have is from 2006. Or can I run the newer 32bit one just fine??
Also, I don't know how accurate or important it is, but I got a 5.9 for my HDD in the Vista System Performance app.
Ok, well here's a shot of the HD Tune Benchark. Everything in 'Health Status' was 'OK' as well. I downloaded Iometer, and am trying to get it working now. It says it's 'Preparing' my hard drive, whatever that means :confused:
Just out of curiosity, are there benchmarks like this, that show data rate/etc. for RAM?
Edit: Oh what the heck?! Iotune just started running, and it did something, and now I have 11mb of free space left on my HDD!! How do I get rid of this thing??
From OP:
That's where I figured AHCI and some device initialization comes into play because it's loaded between Post and Windows. Looking at the mobo specs, the mobo does have a separate RAID chip which may influence the time between post and Windows.
I do have a couple questions that I might of forgot.
1.
Are you running Vista Home premium x64? I know you somewhat alluded to it in asking what version of IOmeter to use, but many times people may put a 32-bit OS on a 64-bit system and not realize it and attempt to install 64-bit software. I'd probably recommend putting x64 on your system.
2.
2GB of memory on a Vista system is okay though you may consider going to 4GB as it might improve performance in the OS. Certainly try looking at your initial memory usage. If it's using 1.5GB at initial login, you may want to look into getting some more RAM as your OS may be using the page more than it needs to be leading to some sluggish performance.
There is also some initial lag while running vista because of superfetch. I'm getting the impression vista has been installed for a short time. So the OS is setting up the tables needed to improve application loading times for later.
That being said, the long windows load times do trouble me because it usually doesn't take that long on a newer install. Then again, I don't use two video cards with two chips a piece. So the driver for the two cards could impact initial windows loading.
3.
The essentials: Update drivers for things like chipset or service packs.
4.
I'm not here to judge, but is your copy of Vista 'genuine'? There are some occasions that people who use pirated windows may have more than just windows installed.
Edit: silly me for having a response window open for an hour. So I missed your last post.
Those HDD speeds are adequate (albeit a little low compared to my ST1000333AS). I'm beginning to think it may be something related to available RAM or loading of drivers.
1. Are you running Vista Home premium x64?
Yes, I am running Vista Home Premium 64
2. 2GB of memory on a Vista system is okay though you may consider going to 4GB as it might improve performance in the OS. Certainly try looking at your initial memory usage.
Well the 2x1GB sticks I currently have are actually only 1/2 of my kit. I do have 4x1GB here, but I have taken out the other 2GB, as the main thing I'm using this computer for is F@H, so outside of the folding clients, there is very little system use. But yes, I would like to pick up a 2x2GB kit for this rig. However, even when I had 4GB in the computer (a couple days ago), it was still just as horribly slow.
Actually I have had it installed for some time now. I think I purchased it about a year and a half ago, and I have only done a fresh re-install once or twice since then.
Well it's been like this when I only had one 9800GX2, and before that with a GTX260, and also before that with an 8600GT.
3. The essentials: Update drivers for things like chipset or service packs.
I do rigorously stay on top of all driver updates as well as system updates. Everything is up to date as of this post.
4. I'm not here to judge, but is your copy of Vista 'genuine'? There are some occasions that people who use pirated windows may have more than just windows installed.
I really hope so :D If not, it'd be news to me. My computer is verified, or whatever it's called though, and it activated just fine. I did however purchase the OEM version of Vista and I wound up picking it up from somewhere online, so who knows :confused:
Those HDD speeds are adequate I'm beginning to think it may be something related to available RAM or loading of drivers.
Well, as I said with 4GB of RAM, and the system completely up to date, it still was as slow as it is today. I'm really curious myself, as I figure with a system like mine I shouldn't see any kind of lag from Vista. Given, it's not a $5,000 super-computer, but it should do very well. I also didn't understand it, as in Windows when I had the GTX260 installed I scored 5.9 on every aspect of the Vista Performance Tool thing.
Out of curiosity, are there other benchmarking tools out there for other components just like HDTune? I'd really like to see how my RAM, CPU, etc. actually come out.
@swoody
I know you dont want to hear this...
Just do a reinstall and start over.
By the time you figure this out you could have already installed a fresh copy and programs that all up to date.
Trust me, I wouldn't mind doing that, but I've done fresh reinstalls 2 or 3 times since I've had this, and it's never been any faster. That's why I'm trying to figure out what's wrong, and why I don't think it has TOO much to do with Windows itself :)
Although I'm thinking to may have something to do with my RAM. I don't know why, but I've never really trusted this RAM, and it's the only thing (except the case and HD) that I've had the entire time...
Maybe if someone wants to donate 2GB of some good 1066 RAM to help me troubleshoot this, I'll check it out ;)
well its not your HDD, and Im fairly confident that its not the BIOS.
hmm do you have any other ram from a diff box you could swap out?
might ask in the distributed computing area......a ton of people run or have run that mobo.
Nope, I wish I did :( Well how about setting up the RAM settings manually in BIOS? I looked into that before, but I have no idea what to set these things to. There's like an entire page of different stats and options there. But I have heard of a lot of people get their RAM to behave much nicer that way??
