- Jul 1, 2004
I bought a GForce 6600 Nvidia AGP from Newegg that arrives the other day, and it came with 256 MB of RAM.
With that amt. of Memory, it should be quite easy to set up 2 x 20" LCD, in which each LCD is max. at 1600x1200.
When I set up 1 monitor, it allows 1600x1200x32 bits.
When I use Nview to setup 2 monitor, (it c/w 3 option, clone, pane, and individual view), I select individual view, and it only allows 1280x1024x32 bit on both monitor.
but if this guide is correct, even w/ 1600x1200, it only needs 7 - 8 MB of RAM
http://www.pcguide.com/ref/video/modesBuffer-c.html
so how come nView only allows 1280x1024?
