Need Help On PSU
lov3rboy408
i just bought the new case having trouble running wires..ANTEC 900 ... my old psu wire is so hard to bend.. can someone give me an idea wat good psu that bendable?? and quality, cheap?
That case is pita on cable management unless you will to take a dremel to it, that my silverstone worked out pretty well after i cut a bunch of holes in mobo tray and few other places.
