need help on my first LCD
eclivia
i just got 37lz800 for my PC, its my first lcd. whats the best way to check for dead pixel and also when i hook it up to a dvd player, it doest look clear. any input would greatly appreaciated
Make sure you are running at its native res to get the best clarity.
To find dead pixels, I look for them while using the LCD.
If you are running at native res and it is still not clear, can you describe how?
Its possible the antiglare coating isnt to your liking.
If so, you may be able to exchange it for a glossy screen LCD.
just fix my own problem, had to sit 10 feet away. As for native reso, i have to wait for my dvi to hdmi cable.
Looks like you are sorted.
The clarity will be massively better when you run at native res :)
yea, cant wait till i get my cable, i want to play COD and AOC on my comp and MGS4 on ps3
