need help on getting a watercooling
blarf
Hi,
is it possible to watercool my processor, graphic card and maybe chipset in my Antec super lanboy??
i have a super lanboy, DFI nf4, opteron 148, x1900xtx.
is it possible? how should i set it up?
what should i get?
sincerely
It probably can be done. It's gonna be a tight fit. Read the watercooling sticky here in this section for more info. You should be able to go to atleast danger den and see what they have that is compatible with your stuff.
Edit, Here's that sticky.
Internally, likely hard as said..Otherwise, if you're willing to mount a rad out back, you could use the Swifty RadBox to put a 2x120 - only the pump (+res if you use one) inside.
yea, i'm just looking at all the options/possibilities. wouldnt bother me if the out is in the back or on the top or bottom....
