Mortgage Paul
- Jan 15, 2006
I have this HP Laptop with a Turion 64 2 Gig processor(ML-37) and a gig of ram running Windows Media Center.
I had McAfee and when they recently upgraded their Security Center/Virus scan, I was one of hundreds with a system brought to a crawl
I have uninstalled all McAfee, ran their removal tools and everything shows gone. Ive switched to Avast Free for now.
When I had he Mcafee, I figured the slowness was a virus/some other problem.
Nothing shows up, not in Adaware/Spybot, Housecall/ other online scanners etc.
I even updated and ran Mcafees before uninstalling and nothing shows.
CW shredder is clean, and not sure about HiJack this, but I didnt notice anything that would worry me.
Anyway, ever since the Mcafee deal, it takes 10-15 minutes to full boot(3 mins XP scroll screen, 2 minutes pure black screen, then the Windows log on screen.........then another 2-3 to load programs /icons)
This all used to take 2 mins tops.
Also, when playing videos/mp3 etc, the audio snaps crackles and stutters like there is 20 programs running..
My CPU usage is only 10-13% except when it does the stutter thing, but nothing is taking much CPU use.
Ram is using 200-400 MB of a gig.
MCafee said there was some conflicts with Free zone alarm and their product.
I did notice that the last program to load now is Zone Alarm but noticed that because I get this "Zone Alarm is Initializing, click here to shut down zone Alarm window"
I never got that prior becasue everything loaded so fast.
Would Uninstalling ZOne Alarm and reinstalling help? It just seems like theres something bogging the system.
Kinda like a bike with a fiddle string tight chains, wheel doesnt roll good. Loosen the chain and all is well.
Has anyone ever done the windows reinstall without losing everything, programs/setttings etc like it shows on Langa.com??
I need help becasue my 7 year old P3 500 MHz with 128 MB of Ram kills this thing. Its only 3 months old also.
Is there any preferred disk/CPU/Motherboard testers to see if thatts the problem?
Also, I ran RegSupremePro and cleaned out all kinds of dead entries etc.
Did nothing to help.
Any suggestions on what to do? Everything works fine, its just incredibly slow.
Thanks
Thanks
