Need help on fan selection.
what are you looking for? if you want low noise go for panaflo L or quiet ys-tech, if you want obsessively low noise go for silenx, if you dont care too much about the noise go for panaflo M or H or normal ys-tech, if you want massive airflow and can tolerate jet engines in your pc get vantec tornadoes
none of those have lights though
