- Jul 1, 2004
I am not versed in clone computer as I only use HP. I'm setting up a IBM Deskstar Model DTLA-307045 and need the numbers to key in at the Microtrend BIOS page under the Delete button.
The drive CHS is 16383/16/63
The AutoDetect that the clone has obviously doesn't work, it detects 255 Heads.
Is there a web page that lists all those numbers that you should key in under the BIOS setting w/ USER defined?
Because, right now, the current setting is:
Cylinder 5607 <-- (the stupid BIOS come up w/ this number, I didn't key it in)
Head 16, Sector 63 Size 46119 <--these 3 settings are correct
But I can't see how the cylinder be 5607 consider the print
out from IBM said 16383.
But I don't think that Megatrend bios allows me to key in a 5 dight number.
I did manage to key in 16383 under Cyl Comp Write, whatever that does.
What I really need is a web site to tell me the all the numbers I should key in under USER defined. Is there such a web site?
