Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
i am looking for a new power supply for the system in my sig. the one i have right now is a cheap one that came with the case. its really loud and hot. does anyone know any power supplies that aren't very loud and run cool for under $40? Thanks
would be the process Id recommend, and Id be happy to help,
provided I dont need to do all the legwork for you
dont buy a PSU based on budget,
buy a PSU that will do the job you require
a budget target is a consideration but
make decisions based on a knowledge of the tradeoffs involved
no other component has the same potential for distaster as does your PSU
