Need help on an lcd decision
mirage220
I'm buying a new 19inch lcd and am a bit torn between these three:
va912b
http://www.newegg.com/Product/Product.asp?Item=N82E16824116353
vx924
http://www.newegg.com/Product/Product.asp?Item=N82E16824116355
samsung 940b
http://www.newegg.com/Product/Product.asp?Item=N82E16824001066
The 940B seemed like the overall best monitor, but the reviews complain about a poor vertical viewing angle (despite the 160degree spec), which turns me away because I'm going to use the monitor for watching tv quite a bit and won't always be sitting at the perfect angle.
The vx924 is supposed to be great, but it almost seems like overkill since I'm not a hardcore FPS gamer, so maybe the va912b would be good enough. Having the extra $50 in my pocket would be nice, but I don't want to sacrifice any significant quality.
Any comments, personal experience, advice, etc?
Thanks
I'm Canadian, so I'll be buying from ncix or canadacomputers, but the relative prices are about the same.
I have a 930B so I'm going to be biased and say the 940B, really though, any of the 3 are good choices.
don't get the cheap viewsonic one, only the vx series or that samsung. If you could get a dell, that would be cheap and again go for the ultrasharp models only. I have owned the 1905fp and now the 2001fp and both are great panels. This 2001fp is pretty awesome at 1600x1200 and sharp clear images and vibrant color.
