Need help on 2 BIOS settings
z0dd
I don't know what to set the 2 settings below to. The board is a Asus P5Q Pro and my video board is a Radeon HD 4870, but will soon be replaced by a GTX 460 (both PCI Express 2.0). I believe both of these board have HDMI output. I'm using the motherboards onboard sound, a Realtek ALC1200. My OS is windows Vista 64-bit.
Setting 1
SPDIF_OUT Mode Setting
Options:
  • SPDIF Output (currently set to)
  • HDMI Output
BIOS help notes:
"If the VGA card has HDMI output and need to use SPDIF signal from SPDIF_OUT header, you need to change HDMI output for HDMI audio output"
The poor English in the help notes has me baffled.
Setting 2
Plug And Play O/S
Options:
  • No (currently set to)
  • Yes
The audio setting is used when you connect a cable from the motherboard's spdif header to the video card so digital audio can be passed through to the dvi/hdmi ports. The two cards you mentioned don't require that, so just leave it set to spdif
The plug and play option should be set to yes unless you're using an os that doesn't handle device configuration.
Correct!
