Ok, so I've purchased a Tuniq Tower and my system specs are as follows:
Conroe E6600
evga nForce 680i Mobo
G.SKill F2-6400 PHU2-2GBHZ 2x1GB @ 4-4-4-12 (800 MHz)
CPU: 1.475 V
Mem: 2.25 V
FSB: 1.4 V
HT(SPP-MCP): 1.2 V
PCI-E: 1.4 V
nForce: 1.5 V
AUX: 1.5 V
Voltage settings read from nTune.
The problems i'm having is that i've used the Tuniq TX-1 Greaze that came with the cooler and i've managed to OC it to 3.6Ghz (400x9) but my temp is at 45-49°C and while in Orthos its 68-69°C...
Doing the Gromac Core stress test it went on for a half hour no problem, I tried the Small FFTs test and it gave me a halt error 11 minutes
Company of Heroes bsod's or just restarts my comp after about 10-20 minutes or so, other games not so much. System Temp is 32°C and GPU is 61°C.
Is there any advice you can give me to either keep the temps down and at make it more stable in general?
Another thing, I was trying to OC my ram cause i've heard/read from various sources that it's great for OC'ing, but I can't get any results from it period aside from stock settings at 2.25V. I've tried loosening timings to 5-5-5-15 (2T) and I get periodic freezing in games (for a period of 5-10 seconds) randomly. I'm fairly new to Conroe OCing as I just got my tuniq yesterday so any help would be appreciated.
Thank you.
Conroe E6600
CPU: 1.475 V
Mem: 2.25 V
FSB: 1.4 V
HT(SPP-MCP): 1.2 V
PCI-E: 1.4 V
nForce: 1.5 V
AUX: 1.5 V
Thank you.
