Need help OC with my new system
djt_
I have never OC before ... so please be specific as much as possible .... I have succesfully OC it using Asus JumperFree's option to 10% (3.7GHz). I know i can get more juice then this ...
Also tell me what would u expect is the highest speed to get out of this system.
Spec
CPU: Intel(R) Pentium(R) 4 CPU 3.40GHz
MB: ASUS P4C800-E Deluxe
RAM: 2xCorsair DDR-SDRAM PC4400 - 512 MBytes
Video: ASUS Radeon9800XT
POWER: Antec 430W
Cpu-z's info
CPU(s)
Number of CPUs 2 (1 Physical)
CPU#1 APIC ID = 0
CPU Name Intel Pentium 4
Code Name Northwood
Specification Intel(R) Pentium(R) 4 CPU 3.40GHz
Family / Model / Stepping F 2 9
Extended Family / Model 0 0
Brand ID 9
Package mPGA-478
Core Stepping D1
Technology 0.13 µ
Supported Instructions Sets MMX, SSE, SSE2
CPU Clock Speed 3398.3 MHz
Clock multiplier x 17.0
Front Side Bus Frequency 199.9 MHz
Bus Speed 799.6 MHz
L1 Data Cache 8 KBytes, 4-way set associative, 64 Bytes line size
L1 Trace Cache 12 Kµops, 8-way set associative
L2 Cache 512 KBytes, 8-way set associative, 64 Bytes line size
L2 Speed 3398.3 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 256 bits
CPU#2 APIC ID = 1
CPU Name Intel Pentium 4 (logical unit)
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer Inc.
Motherboard model P4C800-E, Rev 1.xx
BIOS vendor American Megatrends Inc.
BIOS revision 1016.001
BIOS release date 02/23/2004
Chipset Intel i875P rev. A2
Southbridge Intel 82801EB (ICH5) rev. A2
Sensor chip Winbond W83627THF
FSB Select 800 MHz
Performance Mode enabled
Memory
DRAM Type DDR-SDRAM
DRAM Size 1024 MBytes
DRAM Frequency 199.9 MHz
FSB:DRAM 1:1
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 6 clocks
# of memory modules 2
Module 0 Corsair DDR-SDRAM PC4400 - 512 MBytes
Module 1 Corsair DDR-SDRAM PC4400 - 512 MBytes
Software
Windows version Microsoft Windows XP Workstation Service Pack 1 (Build 2600)
