Can someone please tell me what settings I need to change to overclock my E8400 to 4.0ghz on my P5Q pro? What do I need to set for the FSB strap to North Bridge? also what should I disable in the bios or enable? I have not messed with overclocking in over 4 years. I'm using a 2x2GB G.Skill PC8500 set of ram.
Ok so I just changed the FSB to 450 and the CPU voltage to 1.325 and I'm sitting at windows at this
Im going to run prime but i doubt it is stable yet because I have not changed anything., what else should I change? so far I only changed the following.
PCIE = 100
Line Calibration = Enabled
CPU Spread Spectrum = Disabled
PCI-E Spread Spectrum = Disabled
C1E Support = Disabled
I need to somehow get better airflow, im getting 67C under load at 3.8/4.0.
PCIE = 100
