SomeGuy133
- Apr 12, 2015
What screws does the MB mounting slots use in the Norco 4224? I used some regular case screws that are larger then your typical MB screw and they seem to sorta fit but i would like to get the right size. The holes are huge compared to normal. So you don't think i am stupid. It did come with those raised mounting bolts so it is not like i am screwing the motherboard directly into the case
UPDATE:
You can see the raised mounts. I screwed the MB into those but the holes seem larger than normal MB mounts so the screws seem a little loose when tightening. Any thoughts? Am I safe to turn it on without it shorting?
UPDATE:
