Need help! New system won't power on!
xkilla101
Hey guys, I just put in an ASUS K8N-E Deluxe mobo, a new 480W psu, and an AMD64 3400+. I get everything all connected properly, all fans are plugged in and have power and nothing is intrusive. I go to turn the power on and it blips the power led and the fans start up and then abruptly STOP in under ONE SECOND.
Any ideas what is causing this problem? I can do it multiple times and it just does the same sequence.
Reset your memory, make your your hsf has contact with your core. If you have a videocard that requires power, make sure it is connected.......But just check your memory first. Also make sure your jumpers are set right, not on Clear CMOS.....
Ok, I was a bit dumb and forgot to connect that 4 pin 12V ATX power connector to the mobo, lol. Well, that got it to stay powered on, but now I get no video... When I first plug in the power cord and try turning the system on, the monitor turns on and then displays the "Monitor will turn off in 5 seconds" thing and turns off. The DVD drive's led also stays on the whole time.
Any thoughts on this one?
You are getting no video signal. That is why your monitor says that.
Make sure your video card is completely and properly seated and that the monitor is hooked up to it. Also make sure you have external power attached to your video card if it requires it.
Well, I'm just not sure it's a video issues. I did have an external power plug connected to my 6800gt (with no other connects on that line) and it was doing that. So, I throw in my old geforce4 ti4200 and it does the same thing.
I recently just built a new rig too, having the exact same problem with video, its a abit aa8, intel 560, and a x800xt, everything powers on but no display to the monitor, there was power going to the g card through the bus as the fan still spun without the extra molex plugged in and with it plugged in it still would not power up my monitor, I was told to send them back and as much as i thought it was a g card problem, they found out that it was the mobo to blame, try contacting who you bought it off, see what they say, I should have mine back 2moro, (fingers crossed) :D
