Phandalyon
Guest
- Jun 12, 2001
OK. Lets start at the beginning, here are the specs of the PC:
Gigabyte GASINXP1394 Motherboard
P4 2.4B
512 MB Corsair XMS PC2700 in dual channel
Radeon 9600 256MB
Antec 430W PSU
WD 80gb SATA HD
Windows XP Pro
The issue is this:
Computer was shut down overnight and when it was restarted the next morning, it got locked in an endless boot cycle. Brought the computer in and tried previous working config, same problem. Tried safe mode, same problem.
Opened up computer. The Coolmax 550W PSU had both fans siezed, so replaced with the current Antec. Seagate SATA Hard Drive showed 3 bad sectores, replaced with a WD. All other hardware checked out fine. Installed XP on the WD drive and everthing went smoothly. Got it up and running. Ran for 1 day. Now the same issue has started again.
Only software installed before reboot that started the endless loop was Logitech mouse software which had been run for over 6 months without issues.
Anyone have a thought? Could that Coolmax PSU have fried the motherboard?
I am checking the new HD for bad sectors right now. New Antec PSU is still working fine.
P4 2.4B
Radeon 9600 256MB
Antec 430W PSU
WD 80gb SATA HD
Windows XP Pro
The issue is this:
