Need help - MoBo or PSU is bad?
grit
*** I'm posting this in two different forums in hopes of getting quick answer.
I soft power off my computer and leave it. When I try to start it up again, it won't even get a video signal or go into BIOS. If I leave the computer in sleep mode, it comes on just fine.
Temp fix = turn computer off using front power switch, THEN turn off PSU at switch. Turn PSU back on, then turn computer on with front power switch.
I've replaced the mobo battery, so that's not it. I did not install anything new, so there's no new hardware/software involved.
So, what's the cause? Mobo or PSU?
The mobo is an Asus P5K Deluxe, BIOS 0705
The PSU is a Corsair HX620W.
There are 3 SATA Western Digital HDDs, 2 DVD+RWs, Creative X-Fi board, and an 8800GTX. Power is on a dedicated 15 amp line with just other computer stuff (printer, monitor, etc.)
Can you test a different psu with it? That might tell you right there if that is it.
I think its maybe the motherboard is just acting stupid happens try replacing it. I doubt its your psu.
I have a msi 939 board that does the same thing. Doesn't matter to seem what psu I have connected to it, or what bios etc, it still acts up. I leave it on all the time now and just shut down the monitor:eek:
I would try shutting it down, pulling the plug from the PSU, pressing the power button on the comp for about 8-10 seconds to discharge the capacitors, then trying it.
I had an old computer that did the exact same thing. Think the mobo was a Asus. It might be the PS because I remember switching out the motherboard and having the same issue. About that time though, I left it because I was building a whole new comp.
I'm sad to report that it appears to be a bad RAM module, again.
Quick story. I have had 2 matched sticks of Mushkin XP2-6400 DDR2, which was rated VERY well on several websites. I then added two unmatched sticks. So far, I've had to RMA one of those sticks. I had to then RMA the replacement 6 weeks later. And now 3 months later, I need to RMA it again. Mushkin, what happended to quality control???
