SomeGuy133
- Apr 12, 2015
Again thanks for the help guys. Some new trouble shooting ideas i learned about so thanks a lot.
Okay...either I am a retard or something weird is wrong.
I am trying to access my R7000 router to configure it.
It is just connected to my main desktop.
I am using my builtin intel nic that has always worked.
I am connected to port 1 on the router.
I have rebooted the router and PC a couple times.
I have reset the router once (reset button)
I have tried 192.168.0.1, 192.168.1.1, and www.routerlogin.net
I have renewed IP4/P6 several times in CMD
I have done automated troubleshoot.
ipconfig says default gateway 192.168.1.1 and my ip is 192.168.1.2 and subnet is 255.255.255.0
Cables are good
I can ping router
But I can not login. Every time i try it does "cannot display" as in like page is unavailable.
I also tried to follow all of these steps and check to make sure proxies arent used.
http://kb.netgear.com/app/answers/detail/a_id/1097/~/if-you-cannot-login-to-your-router
I also tried IE, chrome, and firefox.
Is this thing broken or am I missing something?
EDIT: oh also the network lift on port 1 flashes too as if its doing something. The only things connected are my desktop and router. I am trying to configure it before I put it into the network to minimize down time
firebox explicitly says connection was reset before it could load...not sure if that matters.
I also tried again with disabling MBAM and Kaspersky to make sure they weren't doing something stupid too. Still no luck.
I really loathe networks :/
Cables are good
I can ping router
