Metallica_Band
- Oct 23, 2002
Hey there...I have 10 fans in my PC...I have a 6-port baybus and it's quiet when all is low but it can get quite warm at times this way...and it's REALY loud when everything is full blast...
Here is the list of fans I have and where they are:
Fan 1: Front lower fan bringing air inside PC #1
Fan 2: Front lower fan bringing air inside PC #2 (right on top of the above fan)
Fan 3: Rear upper fan bringing air from inside the PC to the outside PC #1
Fan 4: Rear upper fan bringing air from inside the PC to the outside PC #2 (right on top of the below fan)
Fan 5: PSU fan bringing air from inside PC to inside PSU
Fan 6: PSU fan bringing air from inside PSU to outside PC
Fan 7: Side fan bringing air from inside PC to outside PC
Fan 8: Video card fan blowing on chip
Fan 9: Northbridge fan blowing on chip
Fan 10: CPU fan blowing away from chip (WAS blowing on chip but I must have reinstalled the fan on backwards after doing an early Spring Cleaning...too lazy to correct)
As you can see, that's a lot of fans...I have the baybus controlling Fan #1-4. 7, and 10...the PSU has a dan controller built-in and is always on high since the other fans are louder than the PSU fans...
The only fan worth mentioning is the CPU fan...it's a Vantec Tornado and I usually have it set to low (which halves the speed I think)...and I'm not too worried about the cpu since the heatsink is the mighty Swiftech MCX4000 (haven't upgraded to MCX478-V yet)...
Since the baybus is the only thing I have, I was wondering what else there is I could do...I came up with some ideas:
I need a 3rd party video card cooler...I have an ATI Radeon 9700 Pro...stock everything...want it cooler and quieter and reliable...
I should prolly get a 3rd party hdd cooler...the only problem is I have 2 cages...the 1st cage has the floppy drive and 2 hdd's and that's all that can fit in it...the 2nd cage has a fan...nothing else can go in that cage cause it'll block fan #3...MAYBE I can get rid of my 40GB hdd and leave myself with the 200GB hdd...that'll free up room for maybe a hdd cooler...I dunno...any cheap external floppy drives??? The floppy drive can go too if there are any cheap external ones...
What about a new 3rd party CPU heatsink??? at the time, that SwiftTech heatsink was one of the best...but what about those heatpipe thingies or whatever the hell those are called??? When I built my PC, the whole heatpipe thingy concept was kinda new and I didn't want to invest in them cause a top of the line computer with no fans scared the hell outta me...I was a bit skeptical but by now they should have improved it by a BUNCH...I'll consider looking into them now...same the the ones for the video card...or should I just keep the SwiftTech/Tornado combo???
A reliable silent PSU I *MIGHT* consider...but it'd have to be a dual fan and be at least 500W...any ideas??? Right now I have an Enermax EG651P-VE(FMA)...seeing that it says "NO MORE NOISE" on the front of the box and since it has a fan controller on the back of the PSU, I'd think that I can't beat this PSU noise-wise...either that or there wouldn't be much of a difference if I bought a new one...
So what do you guys think??? All my hardware I will keep and use for my 2nd PC...so whatever is replaced will be kept for later use sometime in the future...I don't want to go watercooled since I don't trust it or myself to keep it in shape...any ideas???
THANX
C'YA
THANX
C'YA
