need help! major computer problems...don't know the source
oblivionx
Okay, so recently I've been having some major computer problems. I have to give you guys a little background..so this might be a little read. Here's my hardware specs:
Antec 450W PSU
Asus P4P800 Deluxe with intel 3.0c processor
4x 512MB DDR433 Mushkin level one RAM (2 bought a year ago, 2 bought a few weeks ago)
Radeon 9800 PRO
SB Audigy
ATI HDTV Wonder (removed)
2x SATA 10k RPM 36gb Raptors in Raid 0 (windows drive)
PRI IDE: WD 8mb 250gb, WD 8mb 120GB
SEC IDE: Optorite dd0401 DVDRW, Random DVD-Rom
VIA RAID: Seagate 200gb, Hitachi 250gb
USB: Lacie 160GB external, mouse
About a week ago, I bought an ATI HDTV Wonder capture card. I installed it in my system, and everything was going great for a couple days. Then I noticed that when I restart, rundll32 seemed to hang..the cpu usage would be at about 50% consistently and I had to manually kill it. I traced this problem to be related to ATI's Remote Wonder software. A couple google searches told me that ATI's remote wonder software is quite buggy and does have a lot of compatibility problems. I ended up doing a system restore to before I installed hte HDTV wonder, then reinstalled everything, and it seemed to be going fine. After that, I went to ATI's website and updated the HDTV wonder suite...the DTV decoder, the MMC, etc, the whole works. Upon completing this, I noticed that suddenly none of the capture card features were working. Running DTV or Analog TV resulted in "no signal". I looked online for related problems, but couldn't find anything. I then used ATI's uninstall utility to roll back to the previous version. However, after rolling back, I was getting some language error with all the functions on the software - the TV wouldn't even run. So I figured must be some compatibility problem or something didn't get uninstalled correctly, no big deal. Did a system restore to before the install of the card and went back to reinstall it. However, upon reinstall I was getting the same language problem. At this point I was getting quite frustrated, but it was really only the capture card that was causing problems. I began to uninstall the capture card so I could physically remove it and try it in a different computer when the problems started happening.
In the midst of the uninstall, I got a BSOD. I don't know what the message was since at the time it was set to automatically restart on BSOD. At this point I thought it was some conflict with the capture card, so I powered down, physically removed the card, and got back into Windows. I then proceeded to remove all the ATI HDTV related capture card software. During this process, I got another BSOD. At this point I still thought it was some sort of Windows configuration issue, so I figured a system restore back to before hte card was installed should fix it. Went through the system restore, and after restoring, I got another BSOD. Now I was starting to get nervous. I was afraid I might have to reformat, so I began to back up data onto my other drives. However, during this process I was consistently getting BSODs, sometimes in the middle of a copy, sometimes before. After one of these BSODs, when I started up the computer, I got a BIOS checksum error, and was forced to use the cd to reload the bios. However, it went in a loop. BIOS Checksum error - reload bios from cd, turn off comp, turn it on, and bios checksum error again. I decided to call it a night and try again in the morning. In the morning, bios checksum errors were gone, and it was booting into windows again, albeit with BSODs. I was thinking I needed to reformat, but a google search on my friend's comp told me to check the BSOD error message first, as it might help with debugging. Once I disabled the auto restart, I found out that the BSOD error message was something along the lines of "PAGE FAULT IN NON PAGED AREA" or something like that, but not connected to any system file. Google told me that this is most likely a memory issue - I highly doubted that, but I figured I might as well run a memtest anyway. Ran memtest, went out of the room for about 10-15 minutes, came back and noticed that the monitor colors were all messed up..memtest is usually blue with red errors, my whole screen was blocks of primarily red and blue. At this point, I shut down the comp, took out 2 sticks of RAM and tested the other 2 (my old ones). It failed on the first pass. Tested the other 2 (new ones), and it passed 2 tests. So I figured something was wrong with 1 of the 2 original sticks of ram. I systematically ran memtest with the 2 "good" sticks, and the other 2 sticks individually, both failed. I then tried those 2 sticks individually with the good sticks in the other memory slot, and they still failed. I then ran the 2 "good" sticks under memtest again, and it also failed.
I also noticed that the memory was getting extremely hot. I don't know if this is because of memtest, but my ram has never gotten that hot before (I am always checking since my case is open). I also noticed that my PSU fan was only spinning at about 1200 rpm (in the bios fan speed shows up as red). However, I seem to remember my psu fan always being pretty slow, so I didn't think much of it. I decided to see if my comp was stable with the 1gb of ram that first passed memtest. I needed to use my comp for hw, so I didn't have time for more debugging. Started up, and sure enough no BSOD. The ram was also running much cooler, and windows was running with no problems. This was saturday night/sunday morning. The computer was running fine (and 24/7) until last night, when I noticed it had frozen in the middle of the night. I turned it off, and started it back up, and everything seemed to be fine..until it froze about 25 minutes later. Turned it off again and put my other sticks of ram in, thought it might be a ram issue and previous memtest failures were because of overheating (the hdtv card generates a LOT of heat), but now the computer wouldn't even POST. Took out the 2 old sticks of ram, still no POST. Sometimes ( and this happened a few times in the past few days I just can't remember exactly when) the computer will start up, but nothing will happen, no video nothing, just spinning fans. I turn off the computer and usually unplugging the power cord completely for a few seconds and plugging it back in gets it to attempt to POST. So, I did this, got a bios checksum error, reloaded bios and started up. Still nada, so I reset CMOS by taking out the battery and moving the reset jumper. After this, it started up..but when I entered the bios to change settings it froze after a min or two. Restarted again, once again got into bios (after a few more of those no video powerups), and once again it froze, but this time after less time. On the next successful reboot, it froze even before entering the bios, and now, it will not boot no matter what I do.
Unfortunately I'm in my apartment, so it's hard to test my parts. All my parts are quality, so I don't know which direction I should be looking for a failure. I'm going to try to put the ram in a friends comp later and memtest it, but I have a feeling its either the mobo or the psu.
I was wondering if you guys had any suggestions. I even tried starting it up with most devices unplugged in case it was a psu issue, but no go. I'm really lost on what to do.
Also, it should be noted that my comp is running pretty much 24/7. I can't remember a single freeze or lockup up to the point I installed the HDTV card, and my comp has been running with these devices for about a year (latest addition was 1gb of ram about 2-3 weeks ago, but its been stable since then)
So, for all you who actually read that, thanks, and if you have any suggestions I'd really appreciate it. I need some wya to systematically test devices in my system or something, so I can isolate the problem. It has to be a hardware issue I think, since all these problems occur before booting the OS. I also don't know if this hw issue was always there, or if it popped up as a result of heat or the hdtv card or something.
Thanks again,
Kevin
I tried it again with EVERYTHING unplugged except vid card, processor, and 1gb of ram. It POSTed, and I was able to get into bios and tweak settings for several minutes. Nothing froze. I then plugged the sound card back in, and still everything was fine. This suggested that it was a PSU issue, so I went out to get a new PSU. I just bought a new PSU to test it out (Antec 480W), and still no go. Sometimes it actually gets to POST Screen but it freezes checking IDE drives. Haven't messed around with it too much but I just cleared CMOS and still not turning on. Seems to be the same problem as before. I'm about to go to a friends place to test out the RAM to make sure its ok. Also, I should note that I'm not even getting any error beeps from my mobo, so I really don't know whats up. I would have bought a new mobo to test it out, but they dont' carry the same exact one and I would have to restripe my raid array and lose all my data if I switch boards.
Suggestions are welcome. I have finals next week and I kinda need my comp running to study for them.
Thanks,
Kevin
Have you considered flashing the BIOS? This may be an IRQ conflict. Have you reformatted?
I've cleared CMOS several times, doesn't help. At this point its not even booting up. Formatting isnt an issue as I can't even get far enough for HD format to make a difference.
I just spent the last few hours at a friends house testing my RAM. Here are the results:
Each 512mb stick individually in memtest had NO errors, running for 30 min - 1hr each (3-4 passes)
All 4 sticks at once had 1 error 1 time out of 8 passes. Don't know if this is a fluke error or not, as before when my ram had errors they consistently popped up on each pass or more than one popped up. It could also be an issue with all 4 ram slots being in use.
However, bottom line is that individually the sticks should be fine, so I think I can rule out ram.
Since it appears the psu isnt the problem, looks like its either video/mobo/cpu.
Is it possible the lockups in BIOS / whatever are caused by video card? I suppose it could be, but it seems the BSODs were a RAM issue, which is why I believe its mobo. I am about to take everything out and see if I can get the POST beeps working. I'll post back here as soon as I get the results..I'm going to be messing around with this all night, I need my comp working asap and I will have to order overnight shipping from newegg if I find the problem.
Thanks in advance,
Kevin
another update -
just spent the last 3 hrs or so systematically checking each of my ram chips in each of the ram slots.
I unplugged everything except primary hd, vid card, processor, and 1 ram chip, and moved it to each of the 4 slots.
In the first 2 ram slots (black 1, blue 1), all 4 chips fail individually
In the second 2 ram slots, all 4 chips succeed individually
Any combination of 2 ram chips in the second 2 ram slots succeeds
This leads me to believe that somehow the first 2 ram slots are fried.
My computer is running right now, so I'm gonna leave it on overnight and see if any problems pop up.
From what I can tell I'm pretty sure my mobo ram slots are just dead, unless anyone has any other ideas?
If no one disagrees iwth this assessment, I'm going to go ahead and order another p4p800 deluxe in the morning...
(also another note, with the same mobo I won't have any problems with my raid0 array will i?)
Thanks in advance, this has been one hell of a day and I got class in like an hr
Kevin
I read all of your posts, and the only time I've seen problems like you describe is with a bad motherboard. It may be different for you though. Post back here when you get the new board and let us know if it worked.
Lyquist
thats alot of typin and readin lol..but i think u r right..if i were u though..just to make sure i would take the hw to my buddys and try it out systematically..just an idea but i think the mobo got screwed when u were messin around with the hdtv card..btw leavin case is not a big deal at all..i have done it in the past countless times but touchin the hw depending on what surface u r standing can make a diff..i know coz i killed a mobo that way..and guess what mobo it was lol..p4p800 deluxe
Thanks for reading all that I really appreciate it.
Ordered the mobo this morning, so hopefully it'll be here soon.
And yea my thinking as well is that it got screwed when I was installing the HDTV card, because before that the system was perfectly fine. Now its gotten to the point where those 2 ram slots won't work at all. However, I don't think is from touching the hardware because I always ground myself before touching anything. I've never fried anything from static electricity but I'm always careful to touch the metal of the case first just in case.
I'll let you guys know if the new mobo fixes everything.
Kevin
Sorry its been a while, I was real busy with finals.
Installed the new mobo last night and everything seems to be working perfectly.
Haven't put the hdtv card back in though..not sure if I should exchange it or what...
Thanks again for the help,
Kevin
Kevin
It will be fine I'm sure, pop it in. It was the MB not the card.
take care and glad to hear you worked things out now study!!
