Need help installing
C
Cook_1
Guest
Ok, I know you're not suppose to screw in a motherboard directly into a case because it will short out. I have 3 plastic spacers that came with the board. The problem is, the holes that line up with the board are on like a little hill (don't know how to discribe this) so if I put the spacers in those holes the whole back panel doesn't line up at all. There's only one hole that I can actually put a spacer in that it will line up with the back panel and with the other holes that are on the little hills. So my question is, is it safe to do that? Because I would be essentually screwing it right into the case.
these "hills"... they look kinda like mosquito bites in the metal, right? these act like the plastic standoffs except they're directly attached to the case. if you put the mobo directly on them, the pci slots, backplane, etc line up, right? if so then it screws in. otherwise look for little metal standoffs which came with the case. these will go between the case and mobo.
