Deadjasper
- Oct 28, 2001
Old instructions used to work but now they install v60 instead. I can DL v52 but need some help getting it installed correctly. Google is of no help.
Thanks
Thanks
Why do you want to install an old version?
Because anything newer doesn't support the older addons and extensions that so many of us use would be my guess. I have zero use for anything past ESR 52 and will not use Firefox in newer versions because of that reason. I have some addons and extensions that I use along with all the customizations I've made to my Firefox ESR Portable that cannot be done with newer versions so, basically I'll be saying "Fuck you, Mozilla..." because of it.
But that's just me, of course, and I damned well know I ain't alone.
You should be able to use the "dd" command to clone the 80GB SSD to a larger SSD. This is another example using "dd". Then you should be able to expand the 80GB partition using GParted.
I haven't done this myself, but hope this helps.
Ok I know its not the way most of us like to install Linux software....
But why not just download it from Mozilla yourself.
https://www.mozilla.org/en-US/firefox/organizations/all/#legacy
You can download 64bit or 32bit versions there.
You can then either just hand copy the files to /usr then create a .desktop entry to launch it from Gnome or whatever you need to do for whatever DE your using.
Another option... create your own .deb file
Download the tar ball... it contains /firefox
Create a directory for your firefox files going to your .deb; treat it like its /root create /usr dirs;
mkdir firefox_52.9/usr
mkdir firefox_52.9/usr/local
mkdir firefox_52.9/usr/local/bin
Extract your tar ball somewhere such as your /home/firefox_52.9 (or whatever is logical... or just extract the tar ball directly to the correct location... such as firefox_52.9/usr/local/bin
cp "~/firefox_52.9" firefox_52.9/usr/local/bin (if you extracted it to its own dir)
Now create a .deb control
mkdir firefox_52.9/DEBIAN
nano firefox_52.9/DEBIAN/control
Add text such as;
Package: firefox
Version: 52.9
Section: base
Priority: optional
Architecture: i386
Depends: dbus-glib (>=0.110-1), ffmpeg (>=1:4.0.2-2), gtk3 (>=3.22.30-1), icu (>=62.1-1), libpulse (>=12.2-2), libvpx (>=1.7.0-1), libxt (>=1.1.5-2), nss (>=3.38-1), sqlite (>=3.24.0-1), startup-notification (>=0.12-5)
Maintainer: Deadjasper
Description: Mozilla 52.9
The control file tells the package manager name version ect, and lists dependencies. I'm pretty sure based on the Arch Linux AUR entry that those are the dependencies you would want... the versions are likely all much newer however then what Ubuntu ships... so as this .deb is just for you could either leave depends blank.... or check and see what versions Ubuntu ships... and change version numbers. (>= is simply saying greater then or = to version xxx.x
Once everything is is extracted and you have created your control file. Simply run
dpkg-deb --build firefox_52.9-1
That should give you your own custom .deb installer.
When new versions launch you'll have to create a new .deb... but that's not to big a deal. (just keep your control file around... and update depends if your going that far)
PS.... now do the same for 4-5 other packages, then start bundling your own Ubuntu Spin distro. lol
Have you tried Pale Moon?
