Need help installing fan on heatsink!
Aelfgeft
I've been using a Vantec Tornado for a while on my Thermalright XP-90, and it's kept my CPU nice and cool. However, I'm finally tiring of the whine, and decided to go for a Panaflo, since I had heard they were quiet but powerful. I picked up the following one:
http://www.coolerguys.com/840556001072.html
Now, the problem is that the clips that I used to keep my 92MM Tornado on don't fit this fan. The screw holes on the bottom are blocked off by the screwhole shafts. Anyone know where I can find the proper clips to get this bad boy clamped on there?
Never mind. I was able to use the clips I found for the 80MM fans. Not clamped into a screw hole and perfectly solid, but it seems to hold it tight enough that I shouldn't need to worry as long as I be careful when I move my rig.
