Need Help Installing Drivers!!! URGENT!!
wordomouf123
Ok, I just dowwnloaded the latest ATI drivers form ati.com for my brothers ATI 9600 Pro All-in-Wonder (which has support for dual monitors)
First, I ran Driver Cleaner 2, to clean out the old drivers, then I started installing the drivers and everything went great, except then a message came up saying:
"Setup was unable to complete the installation
Try to setup your display adapter with a standard VGA driver before running setup"
Whats wrong?!? I really need help on this peeople!! Plz!! Im begging you!!
Did you reboot after removing the drivers? You need to do that before installing new drivers. And when Windows asks you to install drivers when it comes up cancel out of the driver installation then install your newer cats.
