Kristoffer
- Apr 14, 2004
If anyone could help me in identifying I'd really appreciate it. All of the sudden my computer has been freezing, but not like a software freeze, like all of the sudden the computer would just stop completely but it would still show a picture on the monitor. I would reboot and sometimes it would do it a half hour or so later. Then after 2-3 times of it freezing like that, whenever I would start the computer up, I would get no post, no sounds, no signal to the monitor nothing except all fans are spinning (power,cpu/video heatsink, all of them) and the harddrive running. HD busy light/cd rom/floopy lights go on and do what they do when it starts up also. I reset it a bunch of times and still, the same thing. I tuned off the computer and let it sit for a bit,turned it back on and then it worked again but then it did the frozen thing again after a bit. Now I've been trying to turn it back on and I can't get it on no matter how long I wait. Don't think it's heat because it's running like 60 degrees in my room, the AC is right near it. The powersupply is only a few months old and its a vantec, not some cheap no name brand psu. Does anyone know what it could be? Thanks alot
