Folks,
I read a lot in the forum about heat problems, no stock cooling solutions, etc but I have a question: on nvidia's Forceware drivers, the temperature that trigers the alarm is 125ºC.
On the threads, it is usual to read that temps above 80 will demage your card. So what is right? This morning, with a conductive ink pen I volt moded both my 7900GT to 1.4v. I was able to increase the gpu clock to 650Mhz and the memory to 900Mhz (1800Mhz effect). My 100% load temp went fron 67~69 to 75~77 (far bellow the 125ºC) limit.
I'm I on any danger of demaging my boards from extreme heat? Or temps on the 70's are high but ok: "Your case will be hotter, limiting the OC capacity, but no harm will be done."
I was thinking about replacing the stock cooler with a Zalman VF-700 or VF-900, but if I could avoid it, I would prefer.
Thanks in advance.
Vaiks
Thanks in advance.
Vaiks
