Need help hooking up Comp. to TV using DVI
WMBlalock
Ok, well i need help hooking up a computer to a high defonition TV using DVI. The comptuer I am trying to hook up has a Radeon 9600XT video card in it. And the tv is a Sony Trinitron High Defonition TV with DVI input. Now, from what i hear, i need a TV tuner card to convert the video signal into NTSC format so i can output it through DVI. Can someone tell me how i can do this and what tv tuner card or what parts i need? Thanks!
-= Mike
Try plugging one end of the cable into the vid card, and the other end of it into your tv.
**sign**
You need Powerstrip and you need to clone your display, thats pretty much it.
I was thinking about the RGB adapter, but i dont know how well that will work and with what aspect ratio/resolution? And about Powerstrip.. just cloning the display does not work.. its darn near impossible to get all the settings right in Powrstrip to make it work right full screen clearly.. i tried for 2 hours today and had no luck with it
- Mike
Powerstrips is pretty much the only way to get it to work. ATI's drivers have stuff in them for custom resolutions like this but so far I hear that most people aren't having luck with them. You need to stop over in the HTPC forum and look there for an answer, or do a search for "Stuff for HTPCs".
